MG 6
Re: MG 6
Příspěvek od Keksin » sob črc 07, 2012 19:00
Tak už i MG6 dostalo naftový motor.
http://www.aronline.co.uk/blogs/2012/07 ... e-to-dawn/
Re: MG 6
Příspěvek od roverix » sob črc 07, 2012 23:21
Správný obsah. To se vleze do povinného ručení do 1850 ccm
Re: MG 6
Příspěvek od Trunda » ned črc 08, 2012 7:33
To uz je dneska stejne vicemene sumak.... Ale pripravovany diesel by mohl znamenat plan expanze na evropsky trh.... Ten clanek jsem neotevret, tak to tam treba pisou :-D ... Me ovsem dieselem neuchvati....
Re: MG 6
Příspěvek od lenham3 » sob lis 03, 2012 11:20
Vcera jsem na dalnici z DOVER potkal MG6 vypada nazivo zajimave jen ma dost vysokou prdel :D
Re: MG 6
Příspěvek od Trunda » sob lis 03, 2012 12:17
..... zkus si domluvit zkusebni jizdu, at nam muzes referovat.... design nepotrebuje komentar, ten je proste v haji...
Re: MG 6
Příspěvek od Austin » sob lis 03, 2012 14:16
On a separate note, I see on Facebook that MG Car Club members can get 20% off a new MG6 with a downloadable voucher.
Re: MG 6
Příspěvek od Trunda » sob lis 03, 2012 23:05
... Tak takovou akci asi skodofkari mit nebudou :D
Re: MG 6
Příspěvek od Keksin » pát lis 23, 2012 17:34
René
Re: MG 6
Příspěvek od René » pát lis 23, 2012 22:33
On the road, the MG6 is transformed. Although the petrol option remains available, we can’t see many people taking it now. The 148bhp engine delivers a useful slug of torque – 258lb ft – and this is absolutely necessary to pull what is a very hefty car, weighing-in at between 1595-1605kg depending on the model. Trickling through the city, all the controls feel well-weighted and progressive and smooth driving comes naturally (unlike the petrol car) – stop-start is a welcome addition; a system that benefits from the MG6′s new regenerative braking system.
However, you are seldom aware of the MG6′s great weight – it accelerates well (0-60mph takes 8.9 seconds, maximum speed is 120mph) and pulls smoothly between 1500 and 4000rpm. The new six-speed gearbox carries a super-tall top ratio (at an indicated 70mph it’s pulling 1800rpm), but the intermediates are well-judged and rarely will you fall outside of the power band.
Mohl by to v kostce někdo přeložit,kdo se vyzná?prosím. Děkuji.
R 400 SDI 99
Re: MG 6
Příspěvek od AnderN » pon lis 26, 2012 10:56
Přečetl jsem celý článek. Nebudu překládat jen ten úryvek, v článku je více zajímavých informací. Ve zkratce:
MG6 se prodává od května 2011 a prozatím se jich prodalo méně než 1000. Auto je prostorné a má vynikající jízdní vlastnosti. Má také dobrou cenu (v příslušném segmentu patří k nejlevnějším). Hlavní slabinu vidí (nejen) autor článku v nabídce motorů, která doposud spočívala v jediném zážehovém agregátu (1.8T, 158 PS), což je v segmentu, kde obecně kralují prodejům dieselové modely, obrovský handicap. Cenově se řadí mezi vozy nižší střední třídy (Golf, Focus) s tím, že se svou délkou zasahuje spíš o třídu výše. Automobilka tak za hlavní rivaly považuje Škodu Octavii (ano, to je stejný scénář) a Opel Insignia (tady si myslím, že soudruzi dost přestřelili, Insignia je celkově o dost větší).
Další slabinu autor vidí v interiéru. Výbava auta je bohatá, ve středním modelu SE naleznete mimo jiné satelitní navigaci, multimediální centrum, dešťový senzor, tempomat, parkovací senzory, nebo 17" kola. Ovšem zpracování a detaily pokulhávají, i když od uvedení na trh se celkové provedení prý značně zlepšilo, auto dostalo např. nový volant a řadicí páku. Tedy se na něm stále pracuje.
Nový celohliníkový 16-ventilový vznětový motor je výsledkem spolupráce joint venture mezi čínskými společnostmi Kunming-Yunnei a SAIC Motor a prošel také dalším vývojem v centru MG v Longbridge (které rovněž patří SAIC, stejně jako celá značka MG), jenž měla za cíl optimalizovat pohonnou jednotku pro MG6. Motory se budou montovat v Longbridge z dílů vyrobených v Číně. Autor připomíná, že MG6 bylo původně konstrukcí anglickou a oproti svému čínskému protějšku (Roewe 550) bylo značně upraveno.
Vznětový motor má 148 koní a prý má dostatek momentu na tahání takového cvalíka (cca 1600 kg). Údajně se dobře řídí a snadno ovládá, stop-start funguje taky dobře a snad má i nějakou formu rekuperace energie při brzdění. Při jízdě nedává svou větší hmotnost moc často najevo, dynamika je slušná (0-100 km/h za 8.9 s, největší rychlost cca 200 km/h). Motor má příjemný tah mezi 1500 - 4000 otáček. Nová 6-stupňová převodovka je vhodně sladěná s charakteristikou motoru a disponuje velkým rozsahem převodových momentů, takže na šestku má při 70 mph (cca 110 km/h) motor jen 1800 otáček za minutu.
Dále autor znova vyzdvihuje jízdní vlastnosti, ale kritizuje elektro-hydraulický posilovač řízení, neposkytující dostatečnou zpětnou vazbu, a brzdy, které se špatně dávkují.
Celkově ale MG6 považuje za dobré auto, tato naftová verze je prý provozně daleko přesvědčivější, než první benzinová. MG předpokládá prodej okolo 1500-2500 vozidel MG6 s tímto motorem ročně a slibuje tomuto autu větší marketingovou podporu, což je považováno také za jeden z kamenů úrazu prodejnosti tohoto typu.
René
Re: MG 6
Příspěvek od René » úte lis 27, 2012 9:24
AnderN - děkuji moc za překlad,já nevzdělanec jsem za to moc rád,že sis udělal chvilku,díky mir:
R 400 SDI 99
lajonel
Re: MG 6
Příspěvek od lajonel » pon pro 31, 2012 16:52
Já také děkuji :-) ale prodejnost zatím nic moc..... a kdy tedy hodlaj prorazit i s levostraňákem ?
Re: MG 6
Příspěvek od Austin » pon pro 31, 2012 22:59
http://www.mgcars.by/index.php?option=c ... Itemid=301
se dávno prodávají, jen stáhli prodej 750 a pochopitelně MG TF
lajonel
Re: MG 6
Příspěvek od lajonel » čtv led 10, 2013 20:26
Tak rusáci si už čvachtaj :) no nemá to zase tak špatnou výbavu :-) člověk by měl jistotu, že tohle auto na silnici druhé nepotká :-)
