no, musim pockat, kym bude teplo, lebo v tej kose sa fakt neda nic normalne neda robit a vyhrievanu garaz (a vlastne ziadnu garaz) nemam k dispozicii
kym cakam surfujem po nete a hladam ako tento problem riesia inde.
nasiel som toto v anglictine,
http://forums.mg-rover.org/showthread.php?t=95650
vyberam jednu cast:
Well, thanks all, problem solved!
As the Major said, it was indeed a naff plastic collar which "grabs" the rod from the exterior door handle.
There was a fair amount of slack in the rod connecting to the collar, so I undid the collar, pulled the rod tight, snapped the collar back on and put a baby cable tie around the collar as tight as I could.
I also wound a 10mm nut onto the top and bottom of the (handily!) threaded rod. These nuts will prevent the rod from sliding either way within the collar. Design fault imo!
Problem solved, total cost of 30mins work and 4p!
Cheers all
tu to riesili nejako inak, ale ja to celkom dobre prelozit neviem (drevorubacske znalosti anglictiny), co vy na to?
P.
